#1276 5 May 2025 12:09 pm
#1277 14 May 2025 2:07 pm
Chuck
Nice work, Rhbush!
#1278 14 May 2025 7:33 pm
Chuck wrote:
Nice work, Rhbush!
#1279 28 May 2025 6:46 pm
Rhbush
#1280 11 Jun 2025 1:44 pm
How exciting to have a new face here! Your build is looking really great Rhbush - I am sorry I missed out on many of your calls for advice -I see SP has managed to furnish you with advice. I wish you best of luck with your first sail!  Regarding cleating the mainsheet - I do (especially when sailing with the outriggers) - I attached a simple cleat to the back of the daggerboard case. I find it's ok - but I do sometimes wonder if a bock with jam cleat might be easier
#1281 27 Jun 2025 5:24 pm
Chuck
Wow!
Way to go, Guy !
#1282 7 Aug 2025 3:11 pm
Welcome Rhbush!
If you google 'Amazon trecking tent personal bivvy tent one man' you will see a rather unusual tent for only £25.00 - Unusual  because it has a zip along the ridge line!
Here is a video.  https://youtube.com/shorts/atb6zGeMjwI?feature=shared
Regards to you all.
#1283 8 Aug 2025 4:44 pm
Cockpit layout:-   https://youtube.com/shorts/I7Pfk_Wlv7I
Happy sailing!
#1284 8 Aug 2025 4:47 pm
#1285 11 Aug 2025 7:18 am
One of my peddling trips!
#1286 5 Dec 2025 6:25 pm
Greetings for the Season to you all!
Cold and snowy suddenly here in the Driftless Region of SW Wisconsin USA. I'm stopping by to see what might be new here, worth noting.
Set a couple of adds for my Waterlust 'kit' this year, drew no responses. Been doing more bicycling (by far!) than when I'd been a'building her, may partly explain why I haven't been motivated to get her back onto the water in a couple years now.
Martin, than custom sail set you had made... I recall you'd sent me the sailmaker who did that for you; are those two sails essentially the same? They sure look like it in that last pic you posted.
Guy you're a stalwart taking Gaia out beyond swinng-back-to-shore distance! And I'm certain that water's cold! I envy you!!
#1287 22 Dec 2025 11:03 am
Hi SP.  Happy Christmas to you all!
I'm afraid the sailmaker I used has gone out of business. My sail size is about half as big again as the mizzen. (Somewhere between the two reefing lines on the mainsail which came with the kit. I can recommend a cut down rig for us elderly gents!
Having said that, I am currently experimenting with an easier reefing system for the  big mainsail. It seems to me that reefing a Waterlust is a very unique process owing to the lack of deckspace and the lug rig - the main problem being preventing the sail and spars going overboard.
I'll post the results of my experiments in the new year.
#1288 11 Jan 2026 8:35 am
Happy New Year!
Reefing:- I have now sailed a Waterlust very happily for several years, albeit I have reduced the rig and added ballast to counter its tenderness.
After a lovely, long, hot, but windless summer last year, I decided to revert to the original mainsail, which is double the size of my cut-down one, to give me more power on windless days.
However, my sailing ground –the Norfolk Broads– requires the ability to shorten the sail quickly whilst underway (as there frequently isn’t a convenient bank you can moor up to) and the unique features of the Waterlust; the forward mainmast position, the lack of deck space and its tenderness make this difficult, if not impossible, with the lug rig – and it is very easy for the boom and sail to end up overboard.
The build manual suggests the use of lazyjacks to catch the boom as you lower the sail, and although I have used these successfully with gaffers, my experience with the Waterlust is that this technique is unworkable as there is too much rope required, the lazyjacks hold the boom, sail and yard at a height that makes the boat unstable, and this is compounded by the boom not being restrained at the mast (as it is with a gaffer).
To address these issues, I have fitted (but not yet tried!) the following solution:-
1.    A ‘hook’ attached low down on the mast to catch the boom when reefing (and yard and sail if required when lowering the sail completely).
2.    A hook on the boom for quick attachment of the tack reefing cringle.
3.    A threaded eye stud at the clew.
The main advantage of the hook on the mast is that it restrains the boom in the same way as the gooseneck does on a gaffer, and the fixings on the boom at the tack and clew dispense with cumbersome reefing lines.
In my view, the beauty of the Waterlust is its simplicity and ‘big boat’ solutions either don’t work or make sailing a chore. I am hoping the above minimalist approach to reefing will work! (I’ll post some pictures when the weather improves).
#1289 18 Jan 2026 3:37 pm
Well! The tack idea didn't work. It was too far away to reach, so I reverted to a reefing line here, leading back along the boom to a cleat over the sitting position.
The hook at the clew worked fine, and so did the boom support on the mast. Here are some pictures:-
Boom support:-
Boom support with boom on:-
Hook at clew:-
Reefing line at tack:-
#1290 25 Mar 2026 8:12 am
Over the winter, I have been experimenting with reefing ideas for the Waterlust, as in my sailing area, it is essential to be able to reef underway.
As owners know, there is nowhere to stow the spars and sails on deck without them sliding overboard, and because of stability issues, going forward to reef, or tie sail ties is out of the question. Everything has to be done from the cockpit.
I should add that the two reefing points on the sail, which came with the kit, are both impractical and unnecessary. Impractical as there are too many lines, and unnecessary, as with a sail this size, you can manage with no reefs or one reef. If you need two, it is time to take the sail down!
Unreefed sail:-
1.    Mast step and reefing points. I fitted a step to the mast for the boom to rest on when the sails are dropped. My first attempt (see the photo in my earlier post) didn’t work, as when the boom twisted, it twisted the supporting ‘hook’. I replace this with a flat  ‘shelf’ arrangement. A step was especially important for me as my cuddy prevents the spars from lying flat on the deck. Next, I added the fore and aft reefing arrangement described in my earlier post.
2.    The rig. When sailing close-hauled with the wind pushing the yard and boom away from the mast, it is important to restrain both spars so that they are kept reasonably close to the mast. This restraint is also important to prevent them from slipping overboard when you lower the sail.
Restraint for the yard:- You can see that the halyard is tied to the end of the yard and then passes around the mast to a block further down the yard. This means that while there is tension on the halyard, the yard is pinned close to the mast.
Yard restraint:-
Restraint for the boom:- A rope passes from the boom (aft of the mast), around the mast and through a fairlead on the boom (forward of the mast) back to a cleat on the boom within reach of the cockpit.
Boom restraint:-
3.    Reefing ties. Tying reef knots at six points along the sail whilst underway is clearly impossible in a Waterlust. I removed the ties from three of the cringles and threaded three lines tied at the boom up through the cringles and down to a fairlead on the other side of the boom. All three lines were joined (so they can be pulled as one) and brought back to a cleat on the boom within reach. These three tie lines, together with the fore and aft reefing points, are all that is required.
The reefing process.
1.    The sail is lowered so that the boom drops onto the mast step and the clew end drops on the deck, where the aft reefing cringle is attached to the hook. The sail isn’t lowered all the way down to prevent the sail and yard from getting in the way.
2.    The reefing tie lines on the boom are pulled so that the sail is gathered in as it is lowered and prevented from dropping into the water.
3.    The forward reefing line is then pulled tight.
4.    The sail is then hoisted, and any tension adjustments needed are made to the reefing lines. No need to adjust the downhaul.
Reefed sail one side:-
Reefed sail other side:-
Sail stowed. I use a bungee tied to the deck with a hook in the middle taken over the sail and spars.
Sail stowed one side:-
Sail stowed other side:-
#1291 6 Apr 2026 12:09 pm
That link didn't work. Sorry! Try this one.
https://www.youtube.com/shorts/t1EXBhWOs9E
#1292 Yesterday 1:38 am
Chuck
Hi Martin —
It looks like you have found a solution that works!
My process for reefing is similar.
1) First I sheet in the mizzen all the way to keep the craft directly into the wind, which calm things considerably.
2) Then I drop the main halyard, most of the way (perhaps all the way).  I make sure that the sail comes into the cockpit.
3) Then I move the carabiner I use for the mainsail clew to the reefing clew, and then tie the reefing clew loosely to the boom (to hold the sail down firmly to the boom, but still allow it to slide).  I also have short lines (~1 foot) tied to the reefing clews — this is what I clip the outhaul carabiner to, so that the length of the outhaul does not need to be changed very much.  So, each reefing clew has two lines permanently tied to it: one for the outhaul carabiner, and one used to tie to the boom.
4) Then I pull in the reefing line.  I just use the standard arrangement as in the plans, which works well for me. (Although it is rather annoying to figure out what to do with all the pulled in reefing line; I should rig up something with velcro)
5) Loosen the mainsail downhaul ( or tack line), but do not let it go all the way.  Estimate where the boom will be with the reefed sail and adjust the downhaul to that poisition (easy with a bit of experience).  I have the downhaul rigged with a 3-to-1 pulley system, and run to a cleat mounted on the side deck amidships, so I can have easy access to adjust the downhaul whenever needed.  That line, the mainsheet (rigged like in the plans), and a home brew 3-to-1 system on the outhaul are the only mechanical advantage I use on the boat.
6) Then I hoist the halyard to whatever height I dare, and snug down the main downhaul.
7) Then, figure out if I want to tie the reefing points.  I can’t reach the fore point, so I usually ignore that one.  But if I have time and things are sufficiently still, I will roll up the foot of the sail and use the other reefing points to secure the roll.  I have a loose footed sail with a boom, and I make sure not to tie the reefing points to the boom.
8) The sail set is different than when unreefed (halyard attachment to yard is about 1-2 feet aweay from the mast), but everything works pretty well.
I have the same sail securing system as you do, Martin, and routinely bungee both my sails to the deck while paddling out to a good place far enough away from a lee shore where I can raise my sails.  The general launching plan is to fully set the rig on the trailer, then drop and secure it to the deck, then launch the boat and paddle out, then raise the rig.
I have the full sized sails as provided by CLC, and I do appreciate having both a first and second reef.  I have definitely used both at one time or another!
I have moved to Washington, DC about a year and a half ago, and sail in the Potomac River among all the monuments, with the airport right there.  Different sort of picturesque (although I think I would prefer Guy’s views in Bergen!). Another advantage is that CLC in Annapolis is less than an hour’s drive away.
My spring plans are to hopefully rig up that jib!  I even opened up the Sailmaker’s Apprentice earlier today, and will start with a simple poly tarp to see how things go…
#1293 Yesterday 6:02 am
Great to hear from you, Chuck, and to read about your rig. (I have the same sail securing system as you, as I copied yours - they say imitation is the sincerest form of flattery!).
Now I have worked out a reefing system which works for me, I am using the full-sized sails, but with a single reefing point halfway between the two which came with the sails.
I find in a gust that the mizzen is more likely to pull me over than the mainsail. On previous (heavier) boats, I have used the mizzen as you do, to hold her into the wind, but for some reason it doesn't work on Gaia - all that happens is I drift backwards until the mizzen fills and then everything becomes unmanageable! You must tell me your secret.
Do let us know how you get on with your jib experiments.
If anyone else has discovered any rigging tips and tricks it would be great to hear from you.
#1294 Today 3:03 am
Chuck
The one thing I make sure to do when "heaving to" with the mizzensheet pulled in all the way is to make sure the rudder is securely set amidships. I have a little spring clamp on the side deck for the tiller stick with a mark on it so I can easily set the rudder to a neutral position. Otherwise with the rudder loose or pushed over to one side, the backwards motion would catch the rudder and turn the boat!
