Nice work, Rhbush!
Nice work, Rhbush!
How exciting to have a new face here! Your build is looking really great Rhbush - I am sorry I missed out on many of your calls for advice -I see SP has managed to furnish you with advice. I wish you best of luck with your first sail! Regarding cleating the mainsheet - I do (especially when sailing with the outriggers) - I attached a simple cleat to the back of the daggerboard case. I find it's ok - but I do sometimes wonder if a bock with jam cleat might be easier
Wow!
Way to go, Guy !
Welcome Rhbush!
If you google 'Amazon trecking tent personal bivvy tent one man' you will see a rather unusual tent for only £25.00 - Unusual because it has a zip along the ridge line!
Here is a video. https://youtube.com/shorts/atb6zGeMjwI?feature=shared
Regards to you all.
Cockpit layout:- https://youtube.com/shorts/I7Pfk_Wlv7I
Happy sailing!
One of my peddling trips!
