Yeah, looking at your earlier pics I had a hunch you'd suss it out without too much trouble. You're doing a fine job of building yours!
With a kit I'd have to think those center points would have been indicated by small holes (not unlike those for wire stitches) where the mounting fastener holes should go. Even with that though, owing to the potential uncertainties of positions in any build, calculating them based on as-built dimensions may give a better result.
Do keep in mind that, once fitted, the amas should have a slight degree of 'toe-in' or at minimum have their long axis parallel to that of the central hull. 'Toe-out' is to be avoided at all costs!
Nice work, Rhbush!
Where did you get that seat design?
I've started using the Hobie Drive more often, and am cursing the bulky CLC cane seat...
Nice work, Rhbush!
Funny that... I haven't had my 'lust out in two years (various reasons) but the urge to get her out again, even with just the Mirage drive alone, is still there.
But I hate the seat my wife gave me for Christmas - at my suggestion - during my build.
And I asked the same question!! RBush replied, it's in a post from a few weeks ago.
https://bandbyachtdesigns.com/other-kit … anoe-seat/
Almost there. Primer on the amas and the aka, should have final coat of paint in the next few days. Rigging is mostly set up but will need some adjustments. There is nothing in the plans for cleating off the mainsheet. I know... you never cleat off the main, but the reality is that you will need to sometimes. Does anyone have a setup for the main that they are really happy with?
How exciting to have a new face here! Your build is looking really great Rhbush - I am sorry I missed out on many of your calls for advice -I see SP has managed to furnish you with advice. I wish you best of luck with your first sail! Regarding cleating the mainsheet - I do (especially when sailing with the outriggers) - I attached a simple cleat to the back of the daggerboard case. I find it's ok - but I do sometimes wonder if a bock with jam cleat might be easier
Here are a few snaps from a recent weekend trip to Sweden with the DCA
It was blowing about 20kts this day - so I just ditched the mainsail and used the mizzen. I need a better 'small' mast for that as it wasn't ideal just placing the mizzen mast in the main mast step!
The effort was worth it mind you!
Wow!
What a nice looking adventure.
Way to go, Guy !
Welcome Rhbush!
Sorry not to have greeted you earlier. Yours looks like a top quality build. Well done!
I have been fitting Gaia out for cruising and experimenting with stowage etc. I think I have found the ideal tent solution!
If you google 'Amazon trecking tent personal bivvy tent one man' you will see a rather unusual tent for only £25.00 - Unusual because it has a zip along the ridge line!
For the Waterlust I cut the floor out leaving about 100mm all the way round and used a strip of this to glue along the zip to make it waterproof. I then fitted four shock cords (one to each corner) and it fits very nicely over the cockpit.
Here is a video. https://youtube.com/shorts/atb6zGeMjwI?feature=shared
I have been on a few expeditions this summer but there has been very little wind here each time I set off so the Hobie drive has come into its own. I will post a few more of my 'live-aboard' modifications soon.
Regards to you all.
Here are a few videos I filmed very badly (Please forgive my appalling tech skills) showing how I have fitted out Gaia for cruising and living onboard - for short periods!.
I won't be to everyone's taste but it works for me. Do ask if you would like any further details.
Cockpit layout:- https://youtube.com/shorts/I7Pfk_Wlv7I
Cooking arrangement:- https://youtube.com/shorts/CeD_77lQYLI
Forward locker arrangement:- https://youtube.com/shorts/Wbt3A_ASCps
Happy sailing!
Had no idea there would be subtitles! Sorry about all the 'ums' and 'err's'!
One of my peddling trips!
Greetings for the Season to you all!
Cold and snowy suddenly here in the Driftless Region of SW Wisconsin USA. I'm stopping by to see what might be new here, worth noting.
Set a couple of adds for my Waterlust 'kit' this year, drew no responses. Been doing more bicycling (by far!) than when I'd been a'building her, may partly explain why I haven't been motivated to get her back onto the water in a couple years now.
Martin, than custom sail set you had made... I recall you'd sent me the sailmaker who did that for you; are those two sails essentially the same? They sure look like it in that last pic you posted.
Guy you're a stalwart taking Gaia out beyond swinng-back-to-shore distance! And I'm certain that water's cold! I envy you!!
Hi SP. Happy Christmas to you all!
I'm afraid the sailmaker I used has gone out of business. My sail size is about half as big again as the mizzen. (Somewhere between the two reefing lines on the mainsail which came with the kit. I can recommend a cut down rig for us elderly gents!
Having said that, I am currently experimenting with an easier reefing system for the big mainsail. It seems to me that reefing a Waterlust is a very unique process owing to the lack of deckspace and the lug rig - the main problem being preventing the sail and spars going overboard.
I'll post the results of my experiments in the new year.
Happy New Year!
Reefing:- I have now sailed a Waterlust very happily for several years, albeit I have reduced the rig and added ballast to counter its tenderness.
After a lovely, long, hot, but windless summer last year, I decided to revert to the original mainsail, which is double the size of my cut-down one, to give me more power on windless days.
However, my sailing ground –the Norfolk Broads– requires the ability to shorten the sail quickly whilst underway (as there frequently isn’t a convenient bank you can moor up to) and the unique features of the Waterlust; the forward mainmast position, the lack of deck space and its tenderness make this difficult, if not impossible, with the lug rig – and it is very easy for the boom and sail to end up overboard.
The build manual suggests the use of lazyjacks to catch the boom as you lower the sail, and although I have used these successfully with gaffers, my experience with the Waterlust is that this technique is unworkable as there is too much rope required, the lazyjacks hold the boom, sail and yard at a height that makes the boat unstable, and this is compounded by the boom not being restrained at the mast (as it is with a gaffer).
To address these issues, I have fitted (but not yet tried!) the following solution:-
1. A ‘hook’ attached low down on the mast to catch the boom when reefing (and yard and sail if required when lowering the sail completely).
2. A hook on the boom for quick attachment of the tack reefing cringle.
3. A threaded eye stud at the clew.
The main advantage of the hook on the mast is that it restrains the boom in the same way as the gooseneck does on a gaffer, and the fixings on the boom at the tack and clew dispense with cumbersome reefing lines.
In my view, the beauty of the Waterlust is its simplicity and ‘big boat’ solutions either don’t work or make sailing a chore. I am hoping the above minimalist approach to reefing will work! (I’ll post some pictures when the weather improves).
