#1 9 Oct 2014 9:49 pm
ianandwend
Fyne Four build
I am going to upload pictures of my Fyne four books here...
boxes and contents
#2 9 Oct 2014 10:02 pm
ianandwend
Re: Fyne Four build
put together the main plants
#3 9 Oct 2014 10:04 pm
ianandwend
Re: Fyne Four build
put the hull together
#4 9 Oct 2014 10:07 pm
ianandwend
Re: Fyne Four build
fillet the hull
#5 9 Oct 2014 10:10 pm
ianandwend
Re: Fyne Four build
glass the hull
#6 9 Oct 2014 10:12 pm
ianandwend
Re: Fyne Four build
forward tank, and transom
#7 9 Oct 2014 10:15 pm
ianandwend
Re: Fyne Four build
rails
#8 9 Oct 2014 10:17 pm
ianandwend
Re: Fyne Four build
forward tank
#9 9 Oct 2014 10:19 pm
ianandwend
Re: Fyne Four build
inwales
#10 9 Oct 2014 10:21 pm
ianandwend
Re: Fyne Four build
bowsprit
#11 9 Oct 2014 10:25 pm
ianandwend
Re: Fyne Four build
last bits
#12 9 Oct 2014 10:27 pm
ianandwend
Re: Fyne Four build
mast and bits
#13 9 Oct 2014 10:28 pm
ianandwend
Re: Fyne Four build
getting the sails and rigging ready
#14 9 Oct 2014 10:30 pm
ianandwend
Re: Fyne Four build
ready to go
#15 9 Oct 2014 10:31 pm
ianandwend
Re: Fyne Four build
and finally on the water
#16 10 Oct 2014 9:12 am
Re: Fyne Four build
A fine looking craft! Well done!
#17 1 Sep 2020 9:35 am
nicgel
Re: Fyne Four build
I am building a Stornoway 12' sailing dinghy.  I was interested in the fibreglassing aspect of the build.  I noticed that the outside fibreglassing on this build was up to the edge of the flat part of the bottom of the boat and the inside sheathing was up to the edge of the buoyancy tanks.
I also noticed that there was no fibreglass tape in the upper planks above either the two fibreglass sheaths inside and outside.  I would have thought that at least fibreglass tap should be laid down on at least the inside of the seam and filleting on the outside.  Paul Fisher recommends this.  So should I do this if I follow the sheathing done on this build?
#18 2 Sep 2020 7:39 am
Re: Fyne Four build
You should certainly follow the advice of the designer Paul Fisher.  The side panels of the above boat are cut differently and there is a joint between the panels which is why there is no need for fabric.
#19 2 Sep 2020 8:23 am
nicgel
Re: Fyne Four build
Perfect.  Just the advice I needed.
