The latest prototype to be taking shape in our shed is an innovative National 12. This is a modern design which promises to be fast and will be sailed in a Winter Series this year. We shall post more as it takes shape.
If you are interested in learning more please get in touch with us by clicking on this link: National 12.
Open Transom.
Under floor buoyancy.
Centreboard case
King Plank
We are not working on it full time but this shows the progress so far
Innovative indeed! I have been poring over the pictures for ages this morning and can't make out what is going on with the chines. Any chance of a side on view?
Floor down
Access to the centreboard pin.
..... Any chance of a side on view?
Gooseneck,
Our normal prototype shed is currently full of other boats being built so this is being built in the corner of the packing area and we cannot get far enough back to take the photograph you are asking for. With luck we will be able to move it in a few days time and will then post a side view picture.
By the way I like your name and would be interested in seeing an avatar!
Deck on at lunchtime
Sorry about the delay but here are the pictures of the boat outside before sanding.
Ah now I can see what you are up to- that curving chine(?) is an interesting idea. Will be fast but there is less buoyancy in the bow than I would expect.
Thank you for your interest in this boat.
I hope that the following helps you to understand what I have tried to do Gooseneck:
By losing the chine into the shear line rather than the bow enables a fine entry to be created without hollows which is easier to form without frames.
There is a flat central plank forming the ‘t-beam’ spine incorporating the centreboard case which runs the length of the boat to encourage marginal planning and lift.
The craft has a tallish stem, the bottom of which is designed to be below the waterline to aid windward performance.
There is a fairly generous longitudinal rocker which lifts the bow when the crew weight is aft during fast downwind sailing.
This National 12 is primarily designed for inland ‘round the cans’ club racing, the semi-circular centre-section providing good roll-tacking characteristics and a low wetted area for light air performance.
The boat is designed with a double floor to be self-draining.
We estimate that it will take between 120 and 140 hours to build this boat.
Some photographs of the painted and varnished boat.
All National 12 boats which are raced have to be measured to ensure that they conform to the regulations. The Kit boat measures and will be raced for the first time this weekend.
Fully rigged and showing off the deck.
Any news or pictures?
A very cold and gloomy Sunday for the first launch.
At slow speeds with a low transom I assume it must be a self draining boat.
Any idea of the price?
The price of the hull kit has been sent at £2,300 including VAT
We have not had any more feedback on the performance but will let you know as soon as it arrives.
Latest Sailing Report
I was delighted with her performance.
Setting of downwind and placing her on the plane she didn’t drop her nose, or particularly raise it, sort of elevated herself throughout her waterline length amazing.
To windward she proved responsive and easy to control. The hull is quite powerful and forgiving. And yes the windward performance is scintillating.
Those watching thought she was ‘art on water’. I have a feeling however that some of the more extreme width and narrow waterline hulls in the hands of experts may in certain conditions prove slightly faster however as a generic high performance ‘forgiving’ hull she is most encouraging.
She is a very forgiving and does all the right things (including not capsizing when the helm takes an excursion overboard).
Upwind she points higher and travels faster than the Lasers and that is the boat’s main strength. Downwind her sweet spot is in marginal planning conditions and she proves very stable on the plane.
The hull buoyancy forward is just right with no hint of nose-diving and the self-draining is excellent .
The kit is now available to purchase via our website.
Is it a stitch and glue kit this national 12 hull?
