#1 19 Dec 2024 4:46 pm
p8ete
Nesting Spindrift 10
Hi all! Complete beginner and my Spindrift 10 kit has just arrived. Have spent today unpacking and setting up my build area, a disused stable on the family farm!
Waiting for some heat sources to arrive to try and keep the space at 10 degrees or above for the epoxy, have a small electric radiator, an infra red electric patio heater and a terrarium heat matt coming. Hopefully this will suffice.
Tomorrow I will install some more lights to work with and build the frame the boat sits in folded, then will make a start on glueing the hull pieces together.
#2 5 Jan 2025 10:18 am
p8ete
Re: Nesting Spindrift 10
Have made some progress but not much over Christmas. I've managed to keep the temp above 10 degrees when it's not too cold but freezing temps outside are unmanageable.
The hull panels are joined and I have glued up the transom and nesting bulkheads.
Unfortunately the screws I used to keep the transom in alignment snapped off when I tried to take them out after the glue had set. I'm wondering if they can be filed back and left in or if I need to drill them out?
I'm now setting up to glue the butterfly joint together.
#3 6 Jan 2025 10:28 am
It's safe to leave the broken screws in and file them flat.  The wood will be coated with epoxy later so they will be sealed in.
If you have any other screws stuck in with epoxy in future, try heating the screw heads with a soldering iron.  It softens the epoxy just enough to allow the screws to turn.
#4 6 Jan 2025 3:19 pm
p8ete
Thanks for the tip Ian.
Some good progress today and have 'opened the book'. The guide said to keep the wires loose but maybe I made them too loose as I have big gaps along the centreline toward the bow end.
Unfortunately the copper wire seems quite weak and has snapped a few times when trying to tighten up the gaps.
Also I tried to unfold the boat in the 'cradles' but it kept getting stuck in the keel notches so ended up doing it on the floor and I'll get someone to help me lift it in to the cradles.
#5 7 Jan 2025 12:54 pm
p8ete
Good progress this morning, I got the boat on to the cradles and installed the nesting bulkheads and transom.
I found the copper wire quite awkward to use and it kept snapping when trying to tighten it so have switched to cable ties instead which I much prefer (except the plastic waste!).
The nesting bulkheads have pushed the chine out quite a lot and I still have quite a gap to close behind the forward bulkhead. I'm wondering whether to accept this gap or trim down the nesting bulkheads?
#6 7 Jan 2025 6:01 pm
p8ete
And further good progress this afternoon. Spoke to Phil on the phone for some useful advice, finished tightening everything up and glued in the breasthook, quarter knees and transom.
The breasthook and quarter knees needed bevelling to fit the hull shape which I did with a block plane by eye and was easier than expected.
