#1 23 May 2021 8:49 am
charboatman2010
Tandem wherry waterline
We are at the painting stage of our wherry build and for a bit of bling would like to paint the waterline stripe.
Question is, how to work out where to put it and how to mark it out on the hull??
Has anyone a really good insight please?
#2 25 May 2021 8:03 pm
Simpsonboater
Re: Tandem wherry waterline
It will depend on how you load it but the only method I've seen is to put in on sawhorses and scribe a line around with a pen on a stick to the ground, measured to height.
Not much above the waterline to see back from the bow, two-up the water comes up to panel 5 in the middle.
#3 14 Jul 2021 7:45 am
charboatman2010
we used lots of the photo's online to work out where the waterline should be and bought a cheap £30 decorator's laser level to mark out the waterline, which worked after a bit of setting up.
