Brave of you and well done! I wished if gone for the pre-coat of epoxy before the glass to stop the outgassing on the interior of my wherry.
Will be a great looking craft once complete. Lots of sanding to come though!
Good progress for sure. It has hardly risen above freezing here for a good week or so so it must have taken some effort to get everything warm for a good while before starting.
A few small bubbles and a bit of outgassing made my mind up to paint the hull too-although I must admit I think I prefer the appearance of a painted hull with a strip deck anyway. If you have some bubbles to sand off and patch don't be too alarmed, it is easy to do. Even after thorough final sanding you'll probably have the odd irregularity but since you are painting the hull you will use a filler and the fairly high build primer. My final result was very smooth indeed.
It is good to have done your first big glass stage. You'll get better at it!
Thanks for the encouragement!
The filling of the bubbles was fairly straightforward - and - having decided to paint the hull I also went for an extra layer of sheeting on the keel line to protect that a bit more as I'll be using it on some pretty rough beaches.
Now - I've got a lot of sanding to do - however it's a very warming activity in these cold days - so that's a plus. In truth I had hoped to be a bit farther on by now but with the lockdown extending ad infinitum why not the build too?
A few days of sanding later and I'm a bit happier - another coat of epoxy is required to fill in the weave of the sheet especially on the side panels but overall the hull is a lot smoother. The random orbital sander I purchased has been a real help and the dust mask a necessity - and an old hoover cast out of house and home worth its weight in gold.
Now to wait for a warmer day for a hopefully final coat of epoxy - and remember not to think it's varnish - it's a lot thicker and it doesn't flow into itself - so I need to work at keeping it even and smooth.
Looking good. It is generally better to have a couple of nice thin (ie warm) coats of epoxy rather than an uneven one. You wil now when the weave has gone of course. Thick epoxy also adds significant weight if that is an issue that worries you. If you still intend to paint it remember the primer does also have a bit of build and will slightly smooth the surface.
That nicely sanded even grey haze takes a while but you will get there in the end.
Incidentally your ply panels have a nice grain pattern. Mine were rather less interesting (another reason for painting).
Thanks Bruce
I'll have another close look at things before painting - the grain is impressive on the panels so it would be nice to be able to varnish them - or keep them partially varnished - there's time to consider options as lots of work to do before then.
I've decided to leave the finishing off the hull until the weather shows more promising signs of warming up.
It's been fun to have a change of activity but fitting the deck forms has not been as straightforward as a first reading of the manual suggests. There's been a lot of careful measuring and adjustment but I seem to be making okay progress and using masking tape and/or cling film tape does help to hold the forms in place. It took a bit of time and reference to other build logs to work out the front of the apron rests on the form at 4.5 feet - anyway the build is definitely keeping me going.
I thought I had got to the stage where I was ready to start attaching the strips onto the forms.
Sadly not - my hope that I could fashion a joint between the 2 strips needed to run the whole length of the deck in situ was quickly dashed as the twist and curve required makes that a non-starter.
So back to the drawing board - and to making more space within the tent for making up the full-length strips.
Undoubtedly the build would be easier with more room and in warmer conditions - but the problem solving is part of the joy of it all (I think..)
Just think, it will be done just as the lakes thaw....
Are you joining the ends with PVA? Not too temp dependent. But you do need a long room!
I'm enjoying your updates.
One step forwards - another back!
I've spent the week sorting out the scarf joints - today was my first chance to see if they worked. They're awkward to get neat - especially as my Japanese saw isn't the longest making the cuts a bit more difficult than they could be with a longer blade - but they work as detailed in the manual.
So - I managed to get a strip in place but then the forms started breaking away from the hull - I evidently don't/didn't have them attached firmly enough to the hull - so progress has yet again ground to a halt while I wait for the extra glue to cure so that the forms stay in place.
On a good note - the temperature is well up and it's making life a lot easier. I have this surreal dream of getting rid of the tent and opening the garage door - well not yet but more space and warmth would be very welcome.
I've been making progress this last week - and dealing with lots of problem-solving and a fair bit of crossing fingers that it will all work out okay in the end. I can't help feeling my deck looks a lot rougher than others I see on the forum but it does seem to be coming together - if I'll be doing a lot of sanding once I've got the deck fixed in place another few stages along from where I am presently.
Apart from the concern about how it'll all turn out - partly due to this being all new to me - I am enjoying the decking - there's lots to work through and slotting another piece into place is very satisfying.
I'm getting through screeds of masking tape and using straps or rope to help with holding the strips in situ while the glue hardens. I also added a couple of scrap pieces of wood on the form on which the end of the apron rests to take the kingplank as I couldn't see how else I could hold it level/slightly proud of the apron as instructed.
Hopefully the weather will allow for continued progress...
The deck will have uneven bits, not least because the strips are not perfectly machined. You will actually plane the deck surface smooth before sanding, which is less scary than it sounds provided your plane is very sharp, and is a very satisfying job
Have you been looking at the Jason Eke videos of him making one of these? I will post a link if you need.They are very helpful.
It all looks good to me. I started my kit almost a year ago and the sun shone for months.Hope you get the same.
Thanks Bruce
I've been watching Jason Eke's videos and they and all the advice and tips on the forum are really helpful - and are an integral part of taking my time - and enjoying the problem-solving
- although maybe I need to borrow Jason's guitar player to soothe me through the awkward bits!
Ha!
He is very calming, and does also make things look very easy.
Hi Tim. jmac58 here (James!). Just been catching up on your blog. Your boat is looking good! I had much the same problems with the forms and getting the first few strips in place was a nightmare with all the twist and no sheer clamp. I made some clamps to hold each strip in place which helped. I don't think MDF is the best material for the forms (next time I would make my own using plywood) as it failed to hold the strips in place at the tight points. Bruce is right, when you finally rub down the deck it all evens out and will look great! My deck looked very rough too but came out OK. I have just bought Nick Shade's book on strip building a kayak as thinking of building another! Keep at it Tim and good luck. Best. J
Thanks James
One more full length strip completed this afternoon - one more to go - and I'll aim for a smooth fit this time - practise makes perfect! I'm learning lots as I go along - I can see why you want to build another - as, although there's occasional desperate moments when the strips seem to have evolved a life of their own, there's also a real joy when I see it starting to come together.
I'm using a lot of pins, as I'm really struggling for space and they're small and handy to keep the gyrating strips in place, and then lots of tape to ensure a tight fit between the strips. The MDF isn't great at holding the pins but - so far - good enough while I get the tape and clamps in place.
Good to hear there's lots of rubbing down and smoothing off to come - hopefully I'll be able to get outside to do a lot of that - the tent has been integral to the build but that would be a lot of dust to contend with
All the best
