#1 27 Jul 2016 10:04 am
Sharpy
Peeler Project
1st attempt to build a boat...
#2 27 Jul 2016 4:06 pm
Sharpy
Re: Peeler Project
05-Stitching-begun.jpeg01-First-bottom-join.jpeg02-Jigsaw-joint-uncovered.jpeg03-Bottom-before-sanding-again.jpeg04-Bottom-epoxied-before-sanding.jpeg06-Hull-part-stitched.jpeg07-Both-sides-stiched-and-bow-closed.jpeg08-Bow-clamped.jpeg09-Bow-stitched---extra-holes-drilled.jpeg10-Bow-clamp-from-inside.jpeg11-View-from-front-before-transom-stitched.jpeg12-Transom-stitched-on.jpeg
#3 29 Jul 2016 7:43 pm
Sharpy
Re: Peeler Project
#4 31 Jul 2016 3:54 pm
Sharpy
Re: Peeler Project
#5 1 Aug 2016 5:43 pm
Sharpy
Re: Peeler Project
#6 2 Aug 2016 7:48 pm
Sharpy
Re: Peeler Project
#7 3 Aug 2016 5:12 pm
Sharpy
Re: Peeler Project
#8 3 Aug 2016 5:34 pm
Sharpy
Re: Peeler Project
So far so good. Theoretically I think I've now got something that will float! Assembling the pieces has been pretty straightforward and everything fits really well. Applying the glasscloth and resin to the upper surface of the bottom panels was easier than I'd thought - largely due to Paul's advice, thanks!
Going by the amount of epoxy I've got left I think I've been overdoing the fillets (although I wasted a couple of batches when I lost confidence in my counting strokes due to distractions of one sort or another)  - I suppose that makes them stronger but the boat heavier. C'est la vie!
Fillets took a lot longer than I'd thought and I think the result is ok so far, if a bit agricultural. Still, I'm learning as I go and the perpetually visible ones aren't too bad. Tanks next, but not much time for a few days...
I'm pretty happy with the look and design of the Peeler now that I see her in the flesh -  and the instruction manual is great. She should suit me well as a pleasure craft for the odd day out and to take myself and my pal scuba diving around the west coast of Scotland. Plenty of room for gear and a nice shallow draught to get ashore in the more remote spots.
#9 10 Aug 2016 8:32 am
Sharpy
Re: Peeler Project
Hopefully getting the hang of this now. Used mixing stick to shape much smaller tacks...
#10 12 Aug 2016 6:22 pm
Sharpy
Re: Peeler Project
#11 4 Sep 2016 6:58 pm
Sharpy
Re: Peeler Project
#12 10 Sep 2016 10:28 am
Sharpy
Re: Peeler Project
#13 11 Sep 2016 10:28 pm
mikey1979
Re: Peeler Project
looking good! looking forward to more updates!
#14 15 Sep 2016 6:12 pm
Sharpy
Re: Peeler Project
Thanks Mikey - work in the way a little just now but hope to do the aft seats next week :-)
#15 26 Nov 2016 3:22 pm
Sharpy
Re: Peeler Project
Back at it :-)
#16 6 Feb 2017 1:28 pm
Sharpy
Re: Peeler Project
Funny how life gets in the way... of life! A little more progress, a little later than I'd intended :-)29-Aft-seat-underside-ready-for-smoothing-joints.jpeg30-Aft-seat-epoxied-and-most-edge-doublers-glied-on-.jpeg31-Aft-seat-glued-in-place-and-front-edge-doubler-glued-on.jpeg32-Aft-seat-knee-doublers-glued-on.jpeg33-Aft-seat-ready-for-fillets.jpeg
#17 13 Feb 2017 12:37 pm
Sharpy
Re: Peeler Project
#18 20 Mar 2017 7:42 pm
Sharpy
Re: Peeler Project
36-Breasthook-fitted.jpeg37-Port-Quarter-Knee.jpeg38-UnderseatBulkhead-fillet1.jpeg39-UnderseatBulkhead-Fillet2.jpeg40-UnderseatBulkhead-Fillet3.jpegmini_37-Port-Quarter-Knee.jpegmini_36-Breasthook-fitted.jpegmini_38-UnderseatBulkhead-fillet1.jpegmini_39-UnderseatBulkhead-Fillet2.jpegmini_40-UnderseatBulkhead-Fillet3.jpeg
#19 20 Mar 2017 7:54 pm
Sharpy
Re: Peeler Project
#20 20 Mar 2017 7:55 pm
Sharpy
Re: Peeler Project
mini_17-First-fillets-port.jpegmini_18-Bow-fillets.jpegmini_More-fillets1.jpegmini_More-fillets2.jpegmini_21-Transom-section-fillets.jpegmini_22-Tank-tacks.jpegmini_23-Tank-fillets1.jpegmini_24-Tank-fillets2.jpegmini_25-Forward-seat-tacked-with-doubler.jpegmini_26-Forward-bulkhead-filleted.jpegmini_27-Forward-seat-filleted.jpegmini_28-Aft-seat-3-pieces-ready-for-glue.jpegmini_29-Aft-seat-underside-ready-for-smoothing-joints.jpegmini_30-Aft-seat-epoxied-and-most-edge-doublers-glied-on-.jpegmini_31-Aft-seat-glued-in-place-and-front-edge-doubler-glued-on.jpegmini_32-Aft-seat-knee-doublers-glued-on.jpegmini_33-Aft-seat-ready-for-fillets.jpegmini_34-February-.jpgmini_35-Breasthook.jpg
#21 20 Mar 2017 7:56 pm
Sharpy
Re: Peeler Project
mini_01-First-bottom-join.jpegmini_02-Jigsaw-joint-uncovered.jpegmini_03-Bottom-before-sanding-again.jpegmini_04-Bottom-epoxied-before-sanding.jpegmini_05-Stitching-begun.jpegmini_06-Hull-part-stitched.jpegmini_07-Both-sides-stiched-and-bow-closed.jpegmini_08-Bow-clamped.jpegmini_09-Bow-stitched---extra-holes-drilled.jpegmini_10-Bow-clamp-from-inside.jpegmini_11-View-from-front-before-transom-stitched.jpegmini_12-Transom-stitched-on.jpegmini_13-Tack-joins1.jpegmini_14-Tack-joins2.jpegmini_15-Tack-joins3.jpegmini_16-First-fillets-starboard.jpeg
#22 1 Apr 2017 12:58 pm
Sharpy
Re: Peeler Project
#23 14 Oct 2017 10:06 am
Sharpy
Re: Peeler Project
mini_43-Bottom-ready-for-first-sanding.jpeg43-Bottom-ready-for-first-sanding.jpeg44-Bottom-strakes-scarf-joints.jpegmini_44-Bottom-strakes-scarf-joints.jpeg45-Bottom-strakes-rounded-glued-and-screwholes-filled.jpegmini_45-Bottom-strakes-rounded-glued-and-screwholes-filled.jpeg46-Outer-hull-during-sanding.jpegmini_46-Outer-hull-during-sanding.jpeg47-Bottom-cloth-covered-and-sanded.jpegmini_47-Bottom-cloth-covered-and-sanded.jpeg48-Fitting-inwales-.jpgmini_48-Fitting-inwales-.jpg49-Inwales-glued-and-clamped.jpgmini_49-Inwales-glued-and-clamped.jpg50-Inner-outwales-readying-to-fit.jpgmini_50-Inner-outwales-readying-to-fit.jpg51-Inner-outwales-glued-and-clamped.jpgmini_51-Inner-outwales-glued-and-clamped.jpg52-Inner-outwales-in-place-grooved-and-tapered.jpegmini_52-Inner-outwales-in-place-grooved-and-tapered.jpeg
#24 14 Oct 2017 11:01 am
Sharpy
Re: Peeler Project
53-Outwales-scarfed-and-clamped.jpgmini_53-Outwales-scarfed-and-clamped.jpg54-Middle-outwale-glued-and-clamped.jpgmini_54-Middle-outwale-glued-and-clamped.jpg55-Middle-outwales-in-place.jpgmini_55-Middle-outwales-in-place.jpg
#25 9 Dec 2017 10:22 am
Sharpy
Re: Peeler Project
