#1 20 Aug 2011 7:25 am
gooseneck
Eastport Pram
..less than 4 hours in to the job. can't believe I have a boat shape
#2 22 Aug 2011 9:48 am
fairplay
Re: Eastport Pram
...wow! - nice...and obviously you're a very quick (and nevertheless thorough) worker wink ...
#3 22 Aug 2011 9:30 pm
gooseneck
Re: Eastport Pram
In the kit the panels are cut and the holes drilled. it is not as clever as it seems but I have not told my neighbour this
#4 27 Aug 2011 8:40 am
gooseneck
Re: Eastport Pram
Got up early to get on withthe build but it is too cold and wet for me so I am catching up with some pictures.  It seems hard to believe that the sun was out a few days ago but here is photographic evidence.
This was a mistake.  Getting the glass to go around the corner was almost impossible.  I thought I could cut off the excess later - on my next one I will cut it to fit and then put a fillet over the ragged edge.
I could not get enough clamps to do both rails - it took more than I expected.  It does not look as though it will matter. (too bad if it does because it is too late)
#5 4 Sep 2011 11:05 am
gooseneck
Re: Eastport Pram
The sidepanels overhung the transom so I sanded them off to produce a perfect fit.  I tried to line up the panels carefully when building but it tu7rns out to be best to have them overhang a couple of mm so that they can be trimmed for aperfect finish.
#6 10 Sep 2011 7:19 pm
gooseneck
Re: Eastport Pram
Luckily I have seen DVD - otherwise  would have worried that it took longer to varnish than build the boat. I borrowed a barn but it took aweek. Farmer Guy thinks it is fantastic
#7 4 Dec 2011 10:26 am
jerryferry
Re: Eastport Pram
I have seen this post before but had not realised what a pretty boat the pram is.
any chance of some action pictures?
Lifelong Angler cool
