#1 14 Mar 2013 3:33 pm
Jason Gillingham
hatch fasteners
I am building a Houdini sailing dinghy and have just made the hatches and was going to fit them with nylon hinges and cam action latches.
Are there any alternatives that I should consider? I am going to paint the interior of the dinghy ivory white so the nylon should blend in reasonably well, but I must admit to being slightly uneasy about using them.
Also what do you use to form a water tight seal around the hatch cover. I have posted some photos of the hatches on the build progress log to help with any ideas that people might have.
Regards
Jason
#2 19 Mar 2013 12:48 pm
Re: hatch fasteners
Jason,
There are many ways to secure hatches and it sounds like you have a solution, or you could purchase some ready made hatches, but I favour your approach.
To make the seal you could try using the gasket seal we use on our kayak hatches.  It has a self adhesive side and it works well and would suit your purpose.  We can get it 6mm thick as well which may suit you better.
https://www.fyneboatkits.co.uk/accessor … -assembly/
Hope this helps.
