#1 18 Jul 2023 7:42 pm
Jays
Tenderly Dinghy build.
I started this Tenderly Dinghy build at Fyne Boats who conveniently are only 15 minutes away from me. I’d helped build a Gaffling 4.1 dinghy there last year for our sailing club and enjoyed the process so much I wanted a boat for myself. Not having workshop facilities I hired space at Fyne Boats for a couple of weeks after the initial weeks build with the guidance of Kurt who is brilliant at getting the best out of a novice builder.
It all went smoothly, the hardest part was fitting the outer gunwales….the first attempt snapped the wood!  We tapered the bow end down to half thickness and tapered back by about a meter, on both strips of wale. This made it much easier and gave a nice taper to the bow which Kurt had suggested would look good…it did!  The lengthiest process was fitting the inner broken wale, getting the blocks just the right size and spacing to match up with frames and the oarlock blocks.
The hull build and outer wales were completed in the first week, fitting the inner broken wale, the seat supports, daggerboard casing etc took up much of the second week, with routing, sanding, final epoxy coat, the third week.
I did make a couple of modifications to the boat. I fitted an inner false bow stem in sapele, partly to look traditional but also to take a bolt through bronze eye bolt for a mooring/tow rope. I fitted a knee and vertical piece to the transom, again to look traditional and the vertical piece of sapele to take bronze bolts for the rudder gudgeons which are bronze rather than the stainless ones provided in the kit.  The seat stiffeners are glued and screwed to the underside of the seats, countersunk with sapele plugs hiding them. I could see no reason why I’d need to unscrew them as per the plans and I didn’t want unsightly screws in the seat tops.
The floor fasteners will be bronze rather than stainless and if I can find suitable machine screws to fit the seats down, I’ll replace those with bronze too. This is all the fault of the kit providing bronze oarlocks….carrying the theme through is a costly exercise!
IMG_2021.jpg IMG_2018.jpg IMG_2017.jpg IMG_2015.jpgIMG_2016.jpg IMG_2014.jpg IMG_2013.jpg IMG_2012.jpg IMG_2011.jpg IMG_2010.jpgIMG_2004.jpgIMG_2005.jpgIMG_2006.jpgIMG_2009.jpg
#2 23 Feb 2025 9:34 pm
ShoreTars
Re: Tenderly Dinghy build.
Thank you for posting this, I am planning to build the same boat on a course with Fyne Boats next year smile
#3 23 Feb 2025 10:04 pm
Jays
They are lovely dinghies, they row very well and sail well too. Enjoy the build, it’s a great experience!
#4 23 Feb 2025 10:06 pm
Jays
#5 24 Feb 2025 9:00 pm
ShoreTars
It looks lovely, the colour scheme really suits it. It's annoying that I haven't retired yet - but this will be resolved by the end of the year and then I'll have the time available to spend 2 weeks in the Lake District smile
#6 24 Feb 2025 9:29 pm
Jays
Both something to look forward to!
If you are staying over whilst at Fyne, I’m just 15 minutes away in Arnside. You are very welcome to see the boat.
#7 25 Feb 2025 10:26 pm
ShoreTars
Thank you, I'll post here once we've arrange the trip smile
