#1 10 Sep 2021 5:26 pm
Jmac58
Petrel Play Kayak
I have started my second build having finished a Wood Duck 12 hybrid last year.  Have bought a band saw, belt sander and a new veritas block plane!  I have used an aluminium strong back for accuracy and made some L spacers.  The plans provided from Guillemot Kayaks are excellent and I am using Nick Shade's book titled Building Strip-Planked Boats and his You Tube videos as my references.  I hope the pics and comments will be of interest and help those thinking of building this beautiful Kayak.
mini_IMG_20210721_163345338.jpgmini_IMG_20210722_160106626.jpgmini_IMG_20210724_114316763_HDR.jpgmini_IMG_20210726_154905409.jpgmini_IMG_20210804_165003403_compress45.jpgmini_IMG_20210823_190103449_HDR.jpgmini_IMG_20210823_190110947_HDR.jpg
#2 11 Sep 2021 8:31 am
teejay
Re: Petrel Play Kayak
Great stuff James - that's taking your boat building to a whole new level.  It looks as if you've made a good start - it'll be really interesting to see how the build develops.  All the best - especially as it gets a bit colder - but you'll have  thought of that no doubt.
Tim
#3 16 Sep 2021 10:09 am
Jmac58
Thanks Tim.  I'm in no rush!  Good to see you are nearly there on your build and looking forward to seeing her (does she have a name yet?) in the water.  Best. J
#4 22 Mar 2022 1:54 pm
Jmac58
mini_IMG_20220316_115218932_compress84.jpgmini_IMG_20220316_125313159_HDR_compress79.jpgmini_IMG_20220318_171133103_compress6.jpgmini_IMG_20220319_134211772_compress75.jpgmini_IMG_20220319_154616980_compress88.jpgmini_IMG_20220318_183021832_compress28.jpg
#5 22 Mar 2022 1:57 pm
Jmac58
Finally making some progress.  Inner stems and the first strips now on.  The robo bevel working well.  Best. J
#6 24 Mar 2022 6:18 pm
Jmac58
mini_IMG_20220323_173841886_compress20.jpgmini_IMG_20220324_113344141_compress34.jpgmini_IMG_20220324_150657251_compress51.jpgmini_IMG_20220324_165656714_compress26.jpg
#7 24 Mar 2022 7:42 pm
teejay
I can see lots that looks familiar from your previous build but lots that's at a different and more complex level - looks like good progress and another lovely boat emerging.  Looking forward to future posts.
#8 25 Mar 2022 2:37 pm
Jmac58
Thanks Tim.  Great to see the post of your wood duck on the water.  I like the contrast of the white hull and stripped deck.  Best. J
#9 30 Mar 2022 9:15 am
Jmac58
Heating up the strips with a heat gun and using straps where the twist is greatest has worked well
#10 30 Mar 2022 9:16 am
Jmac58
mini_IMG_20220329_181906888_HDR_compress91.jpgmini_IMG_20220329_175529440_HDR_compress3.jpgmini_IMG_20220328_144242602_compress48.jpgmini_IMG_20220328_134241651_compress65.jpg
#11 2 May 2022 3:59 pm
Jmac58
IMG_20220425_174603031_compress17.jpgmini_IMG_20220402_155318482_compress22.jpgmini_IMG_20220402_164653471_HDR_compress5.jpgmini_IMG_20220402_165705042_compress77.jpgmini_IMG_20220422_180819596_compress42.jpgmini_IMG_20220425_131624032_compress80.jpgmini_IMG_20220425_143040707_HDR_compress27.jpg
#12 3 May 2022 9:38 am
teejay
Well done James - those last few strips to the bottom of the hull look very intricate and precise.
It's really good to see the boat coming on - you're going to have a very eye-catching result with the choice of strips you've made.
Tim
#13 3 May 2022 8:10 pm
sailingfree
James, that looks really good. Although its obviously more work beveling each strip, the end result looks really tight. I guess one of the positive tradeoffs here is that you don't need to mess round with sanding coves/beads where the strips meet at an angle.
Looking forward to watching your progress on this.
Pete
#14 9 May 2022 9:47 am
Jmac58
Thanks both for your kind words.  I found it almost impossible to avoid gaps at the stern where the strips are at maximum bend/twist.  I used straps to try and meet the forms as staples not strong enough to hold everything in place.  I will fill the gaps with some very fine wood strips and I dont think they will be too visible.  Once you get the hang of using the robobevel, its fairly quick to instal each strip.  I also bought a Stanley 79 plane from ebay and it has been very useful.  I have enjoyed using the block plane to bevel each strip to fit - rather satisfying when you get a tight fit!  Nick Schade's video series invaluable!  Best. James
