#1 13 May 2021 8:58 am
Carmitage
microBootlegger build
My phone has just reminded me that I started this just over a year ago and thought I'd show a few photos of the build so far:
Building the forms
First strips
First half of bottom nearly done
Centre line cut
Planking second half of bottom
Fiddly final strips
And now the foredeck
and the aft deck planking
Deck planked
wetting it down to see what it will look like
Lots of sanding
#2 13 May 2021 9:01 am
Carmitage
Re: microBootlegger build
starting the gunwhale
and a small table my daughter made to keep me company while strip-planking
#3 13 May 2021 9:15 am
Carmitage
First epoxy coat on the hull
more deck fairing
First epoxy coat on the deck
Glassing the deck
Laminating the gunwhale lip
Trimming the excess
Two halves back together, but not joined
Second lockdown then intervened and work stopped for a while...
#4 13 May 2021 9:23 am
Carmitage
Taping up to join the two halves
#5 13 May 2021 9:28 am
Carmitage
How to get rid of that tangled mass of fibreglass and epoxy right up at the bow when the inside joint got snarled up in the last 6 inches and you couldn't face pulling it all out again
Bow end pour
#6 13 May 2021 11:12 am
Carmitage
And now up to date - as of last night, what I hope will be the final epoxy coat, but lots of sanding and varnishing to go (and fitting out)
#7 19 May 2021 9:02 pm
Simpsonboater
Looking gorgeous, I'm tempted to build this one.
#8 26 May 2021 1:16 pm
Carmitage
Go for it - I spent more time than I might have sanding and fairing before the fibreglassing and being elsewhere for the second lockdown didn't help, so it has so far taken rather longer than it probably should have done.  However, my idea was that I would build one that was truly spectacular as I only intended to build one (I felt the stitch and glue boats were very nice (and much quicker to build), but I loved the look and the greater versatility of strip-planking).  I don't feel much of it was difficult per se, but it was time consuming.
Anyway, despite my thoughts of only building one, I'm already thinking of the next (probably a Kahalo SUP, which is stitch and glue!) - I should probably finish this one first, though...
#9 9 Aug 2021 1:00 pm
Carmitage
Starting varnishing - Epifanes takes 24 hours to dry and I have't worked out how to top and bottom together, so 48 hours between coats, plus sanding time.
#10 9 Aug 2021 1:15 pm
Carmitage
after three coats of varnish, I'm now bored.  I've decided to fit it out, put it in the water and use it and then add more coats of varnish over the winter.
Unfortunately it was blowing force 6 yesterday, so the maiden voyage will have to wait a couple of weeks until I'm next down (but at least it gives the varnish a chance to harden a bit more)
#11 9 Aug 2021 1:56 pm
Nice job Carmitage! That shot showing the flawless surface you've achieved on your hull does you credit!
#12 9 Aug 2021 5:05 pm
teejay
That's a terrific build - enjoy using the boat - and better luck with the weather.
#13 1 Sep 2021 9:34 pm
Carmitage
The maiden voyage - very happy and very relieved
