I've now fitted the neoprene hatch seals, hooks on the hatches and bungee cords. The plan was to use the neoprene strip provided with the kit but that proved to not compress enough. I've sourced a thinner strip. Now the hatches are secured, I may well take the boat for a canal launch and leave the rigging till later.
Toggle made for the backband strap. This will slot through a slit in the hip brace.
Backband fitted.
Seat fitted temporarily with Velcro in case I need to adjust the position.
Carrying toggles fitted.
Launch photos posted in the Boat Launches section.
Part of the way through attaching lines and bungee cords. Holes have been drilled through the resin plugs and the tabs then bolted through the deck.
The final deck rigging is now in place so the build is now complete.
It has taken a while due to only being able to make progress at weekends and having to work around other commitments. I really did enjoy the whole build experience.
Lovely boat and she will add a sparkle to our East Devon waters! Looking forward to seeing her afloat!
A beautiful example, well done. Thanks for the log.
