#1 26 Jul 2013 12:30 pm
FyneFour Sailing Dinghy
A recently completed Fyne Four sailing dinghy.  A superb example of the boat.
#2 2 Aug 2013 9:25 am
Re: FyneFour Sailing Dinghy
Beautiful!
#3 2 Aug 2013 9:38 am
Richard I shall pass on your comment.
#4 6 Aug 2013 8:28 am
Gudgeon
How much of this lovely vessel is standard kit and how much customised?
#5 8 Aug 2013 12:24 pm
Like many people this builder has added to the standard hull kit.  The parts that he has added are as follows:
The dark wood trim over the joint between the top two panels on the inside of the boat.
The wooden hook for hanging the sheet onto the aft of the centreboard case.
The wooden trim on the front of the side seats
The wooden trim on the outside of the top panel near the bow
The false bow piece (the kit has the two side panels coming together at the bow)
He has not used the broken inwales which are in the kit.  This boat has also been rigged for single handed sailing.
#6 26 Sep 2013 1:18 pm
rupert
Lovely looking boat. I noticed that the boat is on a combi trailer.  Is it ok to transport the FyneFour on a combi trailer? (Just wondering if the lack of support at the stern is a problem.)  Also does anyone know the make of the combi trailer?
Thanks
Rupert
#7 27 Sep 2013 5:06 pm
I do not know what the make of the trailer is but shall see if I can find out.
I have never used a combi trailer for this boat since we find it light enough for two people to pick up and put in the water.  Other people simply roll the road trailer in.  However, I suspect that the boat will be fine.  The trick is to stop it bouncing.
#8 6 Mar 2025 7:44 pm
CelticSailor
What a beautiful boat?  Is there room to sleep aboard?  Say in between the C/B case and the side bench?
What is the sailarea for the lug rig?
Best,
steve
#9 10 Mar 2025 12:41 pm
It might be possible for a thin person, but I don't think sleeping aboard is something you'd want to do very often, if at all.  The hull has a bit of a vee shape, with only a narrow flat panel down the centre, so it probably wouldn't be very comfortable to lie on.
The boat is gaff rigged with main and jib having a total 7.7 m² (83 sq ft).  More information on the boat can be found on our website.
