#1 16 Jan 2013 6:00 pm
Fyne Boat Kits
Administrator
Website
Plywood Sheets for Plans Builders
Those building a boat from plans may not realise that we also supply high quality okoume marine plywood by the sheet and half sheet.  This is the plywood that we use in our kits.
The wood is from Forestry Stewardship Council (FSC) approved sources and produced in Lloyd's Approved mills. It is certified to the BS 1088 marine plywood standard.
We strongly recommend that you do not use inferior quality wood to build your boat: it often results in the boat having to be repaired within a few years.
